05 yz125 low compression
Just bought an 05 yz125 with a new cylinder and piston, but has major low compression ( push through stroke with just pinky) and only starts being bump started. Any info welcome
sounds like whoever did the top end last screwed up. I would pull the cylinder, or atleast the head and take a look at the piston.
Yeah I was planning on doing that, checking the reeds, and make sure everything is torqued down to spec. What else could it be? Crank seals as a posibility?
