Need 1996 cr125 cdi box
I am looking to get a new cdi as it appears my bike is running out of spark, I will also be buying a new stator, and I have already bought a ignition starter and it didn't fix anything. I looked up the box on ebay and amazon and there really are no 1996 cr125 cdi boxes. I was wondering if I could get a cdi box from a different year and if it would be compatible. Thankyou for your time and links are welcome :D!
I doubt the CDI is bad. 99% of the time, it is a stator or a bad wire. You need to get the shop manual out and test in the EXACT order of the manual. This means checking grounds, continuity tests, ohm tests. Blindly replacing parts is a waste of money and time.
I just read all your other posts about this. Many people told you it was probably the stator. You seem to ignore them for some reason. It can also be the ignition coil but what you describe in all the other posts point to the stator. Test it cold and then when hot immediately when the bike fails to run properly.
