2001 YZ250 POWER VALVE
I assembled my power valve after having the cylinder replated. I don't have any experience with power valves. I did see some videos and they indicated that you should make sure that it open and closes smoothly.
Well after assembling it, I am not able to twist it open and closed easily with two fingers. If I grab it from the middle of the valve I can open and close it and it moves smoothly . At full extension it seems to kind of pop into place, open.
Does it sound right to you guys. Thanks.
At full extension it is moving 2 side valves behind the round covers. I use plyers to rotate mine without the linkage attached.
