Sprockets Change
On a new 250xcf how many links should I have to add to the chain to go up two rear sprocket teeth to 52?
2 teeth is the difference in the axle blocks.  If you have the long side of the axle block facing forward toward the bolt all you need to do is flip it, so the shorter side of the axle block is facing the bolt and you won't even need to adjust the tension.
If you are already on the short side of the axle block, you will need to add links unless it is adjusted to the very back of the swing arm.
Thanks. I did finally figure out to spin the blocks 180 degrees. Sometimes I don't see the obvious!
