modern MX forks that will fit the xr400 triple clamps?
sure be nice to just bolt on a set of new legs on my XR400, I don't want to swap out the triple clamps because I've got a scott stabilizer setup. What's the best solution ?
Edited by pugetsoundsailer
 Modern MX bikes use USD forks. You have to use their triples if you want to use USD forks.   Probably wouldn't need the stabilizer.
 Dampers are worth their weight in gold IMHO!
I agree, no head shake at speed in the woops and keeping your line in tight rocky trails is fantasic, you can hit stuff that would normally rip the bars right out or your hands. But as to a fork swap, after reading through some threads it looks like revalving the stock front end seems like the way to go. Putting in the right springs was like night and day but the rebound is so horrible,  it performs like a pogo stick on hard edges and chatters on the studder bumps.
