2016 dirt candy suzuki team running wp suspension
What does this say about the kyb air forks? They suck? Just curious why they would do that...
250s can only run off the shelf suspension so its slim pickings really, Roczen won MEC with the KYB setup but that will be full factory unobtainium stuff.
Wonder what suspension Townley will run on the 450? Probably spring sprung showa A kit im guessing.
Edited by Rotaholic
When I saw roczen at the mec I slow-mo'd it several times to see what he was running. No markings on his forks. How do you know it was kyb? Kyb air or spring?
250's can only run off the shelf ? Your joking right ? In pretty sure no one can buy the shock or forks that any factory 250 team runs
No that's the rules, most suspension shops have them listed on their website. You can ride the same setup as them if the budget allows
E4.2 Forks and Shocks
a. The manufacturer's original concept of either single or double
shocks must be maintained.
b. In Supercross Lites, the replacement and modification of forks
and shocks are limited to the following:
1. Forks and shocks may be either stock or aftermarket units
listed on the Approved Equipment List. This list is available
from the AMA Racing Technical Department.
2. Homologated inner and outer fork tubes, axle lugs,
cartridge, and piston rod must be retained, modifications
are permitted. All other fork parts may be replaced.
3. Homologated shock body, shaft and reservoir must be
retained, modifications are permitted. All other shock parts
may be replaced.
4. The AMA must receive written notification from the
manufacturer of any superseding of controlled parts before
those parts may be used in competition. The
manufacturer's parts list reflecting the superseded part
must accompany the notification.
5. Approved forks, shocks, and superseded parts must be
available in the U.S. through dealers or distributors to AMA
Pro-licensed Supercross Lites riders for the entire current
season. A dealer or distributor must fill legitimate orders,
accompanied by a 50% deposit, within 15 business days of
receipt. Failure to fill a legitimate order may result in the
canceling of the component manufacturer's homologation.
6. Retail prices of approved forks and shocks may not exceed
the following cost exclusive of all taxes. (The forks and
shock assemblies must be complete and functioning
assemblies, not only the controlled parts.)
7. Both fork legs (less triple clamps) $4,500 $5,175
8. Shock assembly $1,750 $2,000
may be replaced.
Yup, retail on WP Cone Valve forks are $2700 and $1700 for the shock...
Huh I did not know that I need to call up FC and tell them I want a complete front and rear 250f setup
