DRZ 400 Oil Consumption 800 Miles Low Oil
Hey, just making sure my oil consumption is within specs, other posts are kinda vague. I ride what I consider to be hard.  Always in 5th going 50-75mph for 30-60 minutes at a time. I topped my Oil off (Almost 2 quarts/litters) and after 800 miles or so I'm below the low mark on the dipstick. Yes, I know how to properly check my Oil level. I do not have leaks. I do have the black breather box. I use 10-40w Suzuki performance motor oil. 13,000 Miles on original engine.
Edited by Strattton
She'll burn more oil at those speeds/power settings.
It wouldn't take much oil to raise the level on the dipstick.
With 800 mi, at those speeds and 13k overall, I don't see any clear issue with oil consumption.
Edited by shuswap1
Thats VERY low...  no bueno,   i have the same milage and do the same type of riding,  but out here we have to be doing around 80-85,  i use 20w-50 and have never had any oil loss,   i also dropped down the rear sprocket by 3 teeth and it helped relax the RPM's a lot,  i recommend you do the same.
That is probably 4 to 6 oz of oil low.  Not a big deal.
+1 normal oil consumption.
next time you can try an higher quality oil. 100% sinth with high viscosity index and high flash point
Edited by 30x26
it's on the hashmarks, so it's normal. high rpm riding burns more oil. if you were to commute at 40-55mph, you would see much less being used.
if you want to add some in between oil changes, that's fine. the engine won't care if it's missing 1/10th or 1/5th of a quart, like yours is.
no biggie.
Sustained WOT can cause oil to be burned.
Just as a reference, I just got back form the CDR (continental divide ride) about 2 months ago. I did one oil change at about 2500miles. After that, I rode from the canadian border to flagstaff Az all highway...... about 1000 miles at about 65mph. During that time, I did not have any decrease in oil level. My drz now has 10,111 miles.
My opinion, your bike is burning oil. Maybe not a terrible thing, but i can tell you, my bike does not burn that much after only 800miles.
I get the same results with OEM oil. I do tend to rev it higher now riding as opposed to before when I was scared to rev the engine. I have to add in a lot more oil than that within 1000 miles.
I kept thinking it was the coolant needs to be flushed my motor is at 13k miles but I popped it open last night to take a look at the coolant level and it's still full but the motor does feel like it runs out so I'm not sure still
Edited by outlaws
