Whittle09 Posted November 7, 2015 (edited) I got an orion agb e 30 250cc dirt bike very cheap, didnt start, ive stripped engine replaced piston & rings, new gaskets, found out the intake valve was bent.. Cant find the intake valve for that bike anywhere but i found an exhaust valve for a differnet bike with the same measurements, 34mm diameter 91mm length and 5.5mm shaft diameter will this work as an intake valve or will the seat angles be different? Thanks Edited November 7, 2015 by Whittle09 Share this post Link to post Share on other sites
Excitable My Rides (6) Posted November 10, 2015 possibly, is it cheap enough to try? any time you replace a valve you should have it lapped to seat it properly. Share this post Link to post Share on other sites
