CRF pads fit 15 YZ250?
Does CRF front brake pads fit 15' YZ250 caliper? Thanks
they dont, the crf pads fit the 07 and older yz250 front caliper. from 08+ they have smaller pads. If you want some pucker power put on a cr/crf front caliper. anything from i think as far back as the late 90s fits. naturally i would try and find something a bit newer tho
Edited by adam8781
Ok, the CRF caliper will bolt directly on the YZ?
it slides right on the pins of the old one yes.
thanks
There is a big thread on here, but most people change the master cylinder, not the caliper. And if it means anything I think I just read that the Yamaha factory lites guys run the 07 YZF caliper for some reason.
Edited by johnk408
They will with a little modification. I'm run'n them on my 2010,12, & 13. YZ pads have a notch on one end. Honda pads do not. The notch is for the yz clip in the caliper.
I use my Drimmel & notch the Honda pads to match.
They work flawlessly !!
Here is where I get mine
http://www.ebay.com/itm/291373675783?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I don't think there is much difference in the two. I also have an 02 with an oversize non floating & it works great.
the newer yz/yzf brakes have a small plunger in the master cylinder, and small pistons in the caliper. if you go to a crf caliper they have larger pistons. the leverage of the small plunger on the bigger crf pistons creates much more clamping force.
I am running a 08 yz250f master, with a 06 yz250 caliper. for a stock size rotor this thing has some serious stopping power vs the current stock setups.  The crf caliper is about the same size pistons as the 07 ones.
Am I the only one who thinks the stock setup is pretty decent? My stock 2014 seems to have better front brakes then most bikes I've ridden.
Thanks for the link, that's a very informative thread.
My 2010 YZ125 is all stock master/caliper/pads with the exception for a braided front brake line, which was a noticeable improvement.
Might research about some EBC pads before re-ordering the OEM ones at replacement time.
Edited by mlatour
