One mans '16 500 6-days build
So, the '12 never let me down. What a crazy good all around bike. Had no intentions of getting rid of it. I recently got ready to freshen it up and tallied up the cost and decided rather than dump a bunch into it, I'd pick up another one and take what almost 4 years has taught me about the bike and apply it to a new canvas.
So today the '12 loaded up into the truck for the last time....
And it was replaced with a '16....
First order of business will be to dial in the suspension, go around the bike with a wrench on EVERYTHING and then break it in for an hour and then dump the oil.
And then...... Well, I'll address pulling smog, canister, blinkers, fixing the suicide side stand, slight riser, tps, map, xcw rear plate holder, grab handle, hdb guards, stabilizer, lighting, tires, tubes, springs, trip switch for bars, bar map switch, 3g tank, and the list will grow. Unfortunately it'll be a few weeks before I can get started as I have a full plate. But looking forward to it....
  • Like 7
OF - Why did you buy the EXC vs the XC-W and add the street legal kit - you live in AZ?  Had to have the Six Days version? Nice bike - congrats
Edited by AZ Thumpdaddy
Yup, had to have the 6-days. Wanted the front legs and billet triples and liked the graphics this year. Sat on the 350 xcw 6-days today and if it was a 500 it would have been a no-brainier. Making the exc an xcw takes about 3 beers [emoji1]
Nice! What's the difference in the 6 days?
From the web site....
4CS closed-cartridge fork from WP Suspension
Camel seat for improved long-distance comfort
Orange-anodized CNC machined triple clamps
Supersprox Stealth 2-Piece rear sprocket features an aluminum inner ring for reduced weight with steel teeth for durability
Solid rear brake disc without holes or slots for improved heat resistance and reduced pad wear
Floating front brake disc for consistent braking
Front brake disc guard
Front Axle Puller to simplify front wheel removal
Brake pedal wire for extra protection
Orange radiator grills
Orange chain guide
Six Days logo on black wheels
Exclusive Six Days graphics
Radiator fans on the 350 XCF-W Six Days and 500 EXC Six Days for temperature management in extreme conditions
Carbon fiber pipe guard on the 300 XC-W Six Days two-stroke to protect the expansion chamber along with a special charcoal grey silencer with anthracite anodized Six Days logo
Orange chain guide
The 16 500 exc 6 days I saw also had the Ktm steel radiator braces on it.
I can't tell from your pic if your's has a supersprox on it. Several I saw at my dealer recently had aluminum orange and no supersprox. One did have a 45 tooth though. Not sure why some 6 days do and others don't.
Edited by Deepseadan
Did you pull anything off your old bike? Like the steering stabilizer to save a few bucks?
Yes, it has the KTM steelbraces.
No, it does not have the super sprox. It's the 45 aluminum. I'm glad though because after I break it in, when I take it back to get mapped I'll have the dealer swap it for a 50 or 52 supersprox (new chain of course) My buds 6-days was the same way. Dealer made it right. Get to choose what size teeth as they are all the same price. The 350 has a 52 rear, I might do the same.
Yes, pulled off what I thought was still good. Risers, snap, handguards, moose lift handle, double take mirrors, tools, etc. left the rear brake disc guard on the '12 as it was beat. Never had a stabilizer on the '12, but I have an extra one just sitting in the tool box so thought I'd try it. I use one on my 950, but just the high speed setting. Just need to buy the HDB mounting plate so it fits.
14/50 here - best for AZ desert and Ocotillo Wells
I have a gpr on my 500. Best upgrade I've done by far. Totally worth the money. I run mine on 3 or 4 everywhere. Saved me a lot of times.
I have agree, but it depends which tire I run. For my stock 6 days tire 140/80, 14/48 was a must for the desert. Now with my 120/100 maxxis desert it 14/50 is a must. When mounted, the desert it is probably about 1.5" taller. It really changed the gear ratio and my 500 couldn't pull out of a couple of bogs in sand (in 5th and 6th).
got a little done this am.....
Started with pulling the gold wing mirrors off and put the cheap Acerbis one on that comes with the bike.  This will hold me over until the HDB guards w/mirrors arrive.  I've been diehard Cycra fan, but the last two sets I bent in crashes that I felt they should not have bent on.  Going to give the HBD's a try....
Thought that was nice of KTM to provide a shorter kickstand bolt in the briefcase to fix that stupid stock kick stand.  Put that on and the bolt already had thread locker on it.
Bag of goodies.......
These are the same rad guards I bought for my '12 and they worked perfect.  So, gonna keep these....
Put the Moose Handle on I took of the '12....
Couple of minor things I found that I'll fix....
Looks like the bar pad was not put on to my standards.  New zip tie and thats all this needs.....
Ignition switch is hitting the front fork.  That will get fixed before the first ride.  Might just remove it and go with a button.  mask is all the way out, so its got to be removed or modified.
Have an extra xc-w plate holder, but had to order the light... so waiting for that to arrive.....
Thats it for now......
  • Like 10
congrats on the bike. I am a tad worried on my 16 500 exc. I am already at 700 miles on it in just like 2.5 months. This thing is going to have thousands and thousands thousands of miles on it by the time I ever go to replace it.
How many miles on your 12 at the end btw?
No, it does not have the super sprox. It's the 45 aluminum..
As you quoted in the items that come with the 6-days, it has the dual sprocket, aluminum/steel so it's a keeper. Except maybe just for the gearing change.
