2015 VS 2016 Showa Tac
The max pressures in 2015 for the inner is 188it says, and for balance 203 outer 18.8
In 2016 the max is 217 in the balance, did they beef it up?
Not to my knowledge. Other than valving changes and a new lower friction inner/balance chamber seal, the forks are the same as '15. Maybe the newer seal can handle higher pressures?... I don't really know, however the exact same fork is used on the '15 RMZ 450 (just different valving), and their max pressure specs are also higher than what Kawasaki spec for the inner and balance chambers (not sure about the outer).
I've also heard that a couple Kawasaki teams, for 2015, run their pressures above what is specified with no problems.
Edited by RoboHobo
