traileater My Rides (3) Posted November 8, 2015 Hey I picked up a used trailtech vapor and am looking for ideas for mounting the speed sensor on the caliper bracket or fork. Any pics/ideas would be helpful, thanks Share this post Link to post Share on other sites
moto2000 My Rides (3) Posted November 8, 2015 (edited) Mount it on the caliper bracket. Kind of hard to eyeball and line up, but has worked well. Hopefully you have the disc bolt/magnet with the kit. Did you plan on using the temp sensor? I couldn't find a decent place to mount the sensor in coolant line. Edited November 9, 2015 by moto2000 Share this post Link to post Share on other sites
traileater My Rides (3) Posted November 9, 2015 Thanks for the pic, is that a tapping screw holding it?No I got the unit used with no bolt, was going to epoxy one on. Share this post Link to post Share on other sites
moto2000 My Rides (3) Posted November 9, 2015 Yes, I drilled a small pilot hole and used a self tapping screw (was included with the kit) Share this post Link to post Share on other sites
tractorman06 My Ride Posted November 10, 2015 I've got one on my rmx I can take pictures tomorrow. And I turned out an aluminum bung that I'm going to try to weld into the top of the radiator for the temperature sensor just haven't gotten to it. Share this post Link to post Share on other sites
moto2000 My Rides (3) Posted November 10, 2015 I've got one on my rmx I can take pictures tomorrow. And I turned out an aluminum bung that I'm going to try to weld into the top of the radiator for the temperature sensor just haven't gotten to it. That's a better idea. Like to see the finished product when you get it done. Share this post Link to post Share on other sites
traileater My Rides (3) Posted November 13, 2015 My caliper is a bit different then the above pic, I had less room to work with. I slid it down the bracket to where it lined up with the bolt rotation then penciled the alignment. Had to unbolt it to dill and mount it. But the clearance is all good, The bike is a 1996 model RMX. Yo can just see the corner of the black plastic in the pic.Next thing is I did the math for the wheel size and put it in. its simply wheel dia. in mm ÷ 3.14. One thing I find odd is why the placement of the sensor/pickup isnt part of the equation? I will check the distance on the vapor to a forest service road marker.I didnt have a place to epoxy a magnet to my aftermarket rotor so I made a 6mm bolt with a magnet in the center, like the proper one from TT.No ideal options for mounting the lcd, the brake line is in the way no matter what. My home made bracket has it forward of the hose rather then below it. I tapped into the headlight for power.Cool unit, bought it for next to nothing. Share this post Link to post Share on other sites
tractorman06 My Ride Posted November 25, 2015 I forgot to post the picture of the bung I made for the temperature sensor. I don't have a tig welder as of now. So this winter I'll pull it off and see if my buddy will let me borrow his for a bit. Share this post Link to post Share on other sites
traileater My Rides (3) Posted November 25, 2015 Nice. I never got a chance to test drive vapor as the temps have plummeted well below freezing. Supposed to be an elnino winter?? Share this post Link to post Share on other sites
TEGRITY RMX My Rides (2) Posted June 11, 2016 For the temp sensor on mine I used the M6-1.0 sensor and installed it in place of the top bolt on the power valve side cover. Bolt hole is not deep enough as is, so needs to drilled a bit deeper. I used a bit just barely larger than the tip of the sensor, shot some heat sink paste (from radio shack) deep in there, and some blue loc-tite on the threads. (as only about 1-1/2 threads actually thread in) Just be VERY careful not to get too tight and strip the threads!!! Seems to work fine in this location. Good thing is even if I were to have a hose pop off or burst and loose all my coolant, the sensor still reads. 1 Share this post Link to post Share on other sites
moto2000 My Rides (3) Posted June 12, 2016 Great idea! I like this better than tapping into a coolant hose and potentially causing more problems than it's helping. Good catch on using the heat sink compound. Share this post Link to post Share on other sites
TEGRITY RMX My Rides (2) Posted June 13, 2016 (edited) Thanks! The hose that exits head on my RMX has no good straight sections, so that really wasn't an option. Didn't want it between radiators, or in the return line. Originally I was going to weld bung in lower radiator tank like tractorman, but chickened out. Welding thin aluminum is hard enough. (I did weld a beer can together once for practice lol.) When you have unknown types of aluminum that melt at different temps, it gets extremely hard. My luck I would have blown a big ol hole in it, or melted the aluminum soldier they use to join tanks to core. The mounts they give you for LCD suck. Here's what I did for mounting. Went with stainless so it wouldn't rust. Here's my old vapor mount. It's kind of rough but works. Feel free to print to scale and use as template. You might want to modify it a bit to give access to battery. I didn't know when making it that battery only lasts about a year... Edited June 14, 2016 by Jeremyf1 Share this post Link to post Share on other sites
