Help
Hello I am new to dirt bikes and just got a honda crf 450r, i noticed earlier that it would idle low and die out so i messed with the Mixture screw i think it is (has a series of 1-4 numbers on it under the carb) while it seemed like it had a high idle after I turned it a full turn. I also noted that the head of the exhaust was a deep orange. So I then proceed to turn the bike off, once I did coolant steam shot out of the overfill tube then the water pump hose that runs by the muffler burst (the hole was the probably the size of a tip on a ball point pen) this hose was directly under the exhaust. It also had a far amount of popping when you would come off the throttle before this. Thanks in advance for any suggestions.
Very weird ,cause normally a glowing healer would mean your running it to lean,but then its pooping alot means its too rich
