BSR42 carb spacer
I need the dimensions of the carb spacer that was made by Mudguy or anyone else that has turned one for themselves. I do not have a stock Keihin to measure and have already messaged Mudguy with no response.
Thanks
Thanks
Dont understand,I mounted my 42mm carb no spacer?
I don't have the spacer size but, I do still have the stock Keihin carb.
4.4" long
1.73" engine side
2..32" air filter side
Hope this helps.
Perc
Thanks! Perc
Is your air boot stretched ?
Thanks! Perc
I removed intake manifold,put carb in vise.Heat gun to manifold.Then removed air box with boot,heat gun clamped it.Let it sit few days.Installed carb with manifold attached.Then pushed air box/with boot on carb.Then bolted air box on.
I've tried BTR's method a few times now with no luck. Does anyone have a spacer that is not using it and want to sell ? I'm also all ears for other ideas.
Thanks guys
I had no access to a lathe to mill up a spacer so I ended making a spacer between the air box & the boot that attaches to the carb. 2000miles later, still fine & no leaks.
Thanks guys
this will sound crazy lol, but I took my carb to home depot looking for something that would fit. In the section with the hard plastic coupler's for irrigation or plumbing I found this. https://goo.gl/photos/EKkKmvQypuVnPT8G8. Had to sand the inside down a little to fit over the carb and it's a tad to long so you would have to cut a half inch or so off the other side. But after that fit like a charm, 3 years no problems, cost 2 bucks. Only reason I took it off the bike, is I screwed up the throttle on it, so I got a another one. Edited by dlock5
It's not running, yet. The boot will not stay attached. It keeps slipping off when I tighten the clamp. No problems with the manifold.
Thanks dlock !
Edited by nomad221
Decided to grind down the inside lip of the boot with the mighty dremel with a stone attached and the carb fits and doesn't slip off after clamping it. Can't wait to ride !
