jeredlee Posted November 8, 2015 Bike won't idle right and is popping on the decel loud. Bike has new motor piston head and sleeve. I put a Jd jetting kit 45 pilot 170 main blue needle on 3rd clip. One thing I noticed is the o ring for air screw seems a little big would this cause these problems. Any help would awesome thanks. Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 8, 2015 year make model hours jetting other tuning Share this post Link to post Share on other sites
jeredlee Posted November 8, 2015 2005 Yamaha yz450f 0 hours on new motor. Jetting 45 pilot 170 main blue needle 3rd clip down. Share this post Link to post Share on other sites
Dexter42 Posted November 9, 2015 Loose air boot? Air leak? Use a new header gasket? Or the plate that goes sandwiched agains the slide has a rubber seal that goes bad and needs replacing as well. Jetting sounds reasonable and fuel screw, how many out? Share this post Link to post Share on other sites
jeredlee Posted November 9, 2015 Has new header gasket. Bike ran good before rebuild. Carb did sit for 5 months. I did replace the rubber seal on slide plate 4 years ago. Fuel screw 2 turn out. Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 9, 2015 Bike won't idle right and is popping on the decel loud. Bike has new motor piston head and sleeve. I put a Jd jetting kit 45 pilot 170 main blue needle on 3rd clip. One thing I noticed is the o ring for air screw seems a little big would this cause these problems. Any help would awesome thanks. ok, so you have a lean condition, with the throttle closed. - leaking fuel screw - hot start not dropped in cavity all the way, now leaking - loose carb boots - passage above pilot jet is not perfectly cleared out (use fishing line)' - pilot jet is partially corroded (replace it) 1 Share this post Link to post Share on other sites
jeredlee Posted November 9, 2015 Ok thanks krannie . The pilot jet is new but will check the passage above. Going to replace oil ring on fuel screw. Is there a way I can check hot start plunger? Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 9, 2015 Ok thanks krannie . The pilot jet is new but will check the passage above. Going to replace oil ring on fuel screw. Is there a way I can check hot start plunger? The plastic nut that holds the hot start plunger cable can crack, and then the spring tension on the hot start plunger is compromised, causing it to leak......or, water has gotten inside the pluger cavity (common) and corroded the plunger up just enough for it to leak. The YZ has the hot start on the top of the carb, which is hard to get to, but it can be done by only removing the tank, and loosening the carb so it will rotate a bit. I think it's a 12mm open-end wrench that will fit down in there..... but a ground down one works really well....if you have an extra one to grind down... Once you get it loose you can kind of get to it with your fingers.... You are best to replace the plastic nut with an aluminum one (ebay, zip ty, etc) Share this post Link to post Share on other sites
jeredlee Posted November 9, 2015 Ok thanks I already replaced the plastic hot start nut with a zip ty one a couple years ago do I will check the plunger and go from there thanks for the help . Probably going to be a clogged pilot passage or leaking fuel screw. I hope will let you guys know how it goes thanks again. 1 Share this post Link to post Share on other sites
jeredlee Posted November 12, 2015 Got the bike dialed in finally. Had a broken oil ring on the fuel screw and a I hate to say this but I put the slide plate in upside down. I felt like A dumb ass. But I got it all figured out. Thanks for the help. Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 12, 2015 DUMBASS! ( last time I did it was 7 years ago...) 2 Share this post Link to post Share on other sites
jeredlee Posted November 12, 2015 Still pops a little on decel but I think I just need to tune it on the trail. Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 12, 2015 Still pops a little on decel but I think I just need to tune it on the trail. It should pop a little. If you down shift one gear too many it should pop even more. if you tune that out, you will loose throttle response.... 1 Share this post Link to post Share on other sites
jeredlee Posted November 15, 2015 Ok so I took the bike out yesterday and the bike runs amazing. But it's still a little stubborn to start hot or cold and some times the idle will not back down. I tried adjusting the fuel screw and the idle and it kept changing. One time I even turned the fuel screw in all the way and the bike didn't die. Stumped..... Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 15, 2015 You say the motor has 0 hours, but what about the carb? Needle jets wear out Did you adjust the fuel screw on a hot motor, lowest possible idle with idle screw, starting at 1 turn out on the fuel screw? ...and you ended up with how many turns out on the fuel screw to reach highest idle ? Share this post Link to post Share on other sites
jeredlee Posted November 16, 2015 The carb has been rebuilt. With a Jd jetting kit new .170 main 45 pilot blue needle on 3rd clip down all brand new new diaphragm and all new seals and oil rings all other jets are stock and 8 years old. Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 16, 2015 The carb has been rebuilt. With a Jd jetting kit new .170 main 45 pilot blue needle on 3rd clip down all brand new new diaphragm and all new seals and oil rings all other jets are stock and 8 years old. Your needle jet (not the jet needle) is a wear component, and needs to be replaced after a 100+ hours. Share this post Link to post Share on other sites
jeredlee Posted November 16, 2015 Ok I will try that I have had the bike sense 2006 and never changed that thanks. krannie Share this post Link to post Share on other sites
jeredlee Posted November 25, 2015 Ok put the needle jet in last night and bike fired right up. And once it was warm first kick three in a row. Thanks for the help krannie . 1 Share this post Link to post Share on other sites
