OZZIE_KLX Posted November 9, 2015 Hey guys,Can anyone confirm whether 08 kx450f front wheel spacers will work on the klx450 that has had the speedo gear removed?Or do I have to get one of those massive eliminator cover things? Share this post Link to post Share on other sites
KLX Fan Posted November 10, 2015 (edited) I have one on my bike. I had the hub machined so I could still use the speedo. Seems to work fine Edited November 10, 2015 by KLX Fan Share this post Link to post Share on other sites
dstewart My Ride Posted November 10, 2015 The KX front wheel spacer is not the same width as the KLX speed sensor hub. IIRC, there is a 2mm difference which can put the forks into a bind. You can use the KX front wheel an spacers or the KLX front wheel and a speed sensor removal spacer like this; http://www.langstonmotorsports.com/eshopprod_cat_2443-25296_product_818903.Zeta_Aluminum_Meter_Gear_Cance.htm Share this post Link to post Share on other sites
