Ktm 500 exc tire pressures
Just wondering what tire pressures people are running and for what conditions? What's best?
For me-
10 psi front and 12 psi rear for off-road. Hard pack and sand.
15 psi front and rear for street.
I have the stock six days front and the desert it rear, and regular tubes (so far).
For me-
AZ and California desert - 13 front and 12 rear running Dunlop AT81s and HD tubes
For me-
I run 15 psi for all off-road conditions.
Depends on Terrain,the tire,the tube and how fast you will be going....no good answer.
Over the years I used to run about 15lbs for all desert conditions. However, with the quality of tires and tubes, I found you can run lower pressure I run about 13.5. However, if you are running a lot of street, you want a little higher pressure. 15-18lbs.
