Ktm 450 exc exhaust and triple clamps
Hi just got a 14 450 exc it has the sxf slip on, on it has anyone done this or should I put the exc slip on back on.
Also I was wondering if anyone runs the sxf billet triple clamps
EXC has a spark arrestor, so if you bush ride, then you'll want that.
I run billet 18-20mm triples from a 2007 SX. I have a 2006 exc so no extra parts needed. The new style fender requires an adapter (Nihilo makes one) to mount onto triples designed for the older style triples. The billet clamps are a noticeable improvement in front end feel over the cast version.
I fitted the SXS billet triple clamp on my '13 500-EXC & didn't really notice any difference in the handling. The only downside was the turning circle was affected. (Too wide) I ended up removing the lock nut from the stop bolts so I could shorten the turning circle in the bush.
