Crazyced Posted November 9, 2015 (edited) I have a Magura clutch kit installed on my 2008 CRF250R and I broke the lever in half during a fall. I am now trying to source a replacement and was wondering, could I buy anything that is said to fit a KTM fitted with an hydrolic clutch. Edited November 9, 2015 by Crazyced Share this post Link to post Share on other sites
YZCas27 Posted November 9, 2015 Hi I also have the hacks magura kit on my 16 Yz 250. There is a company called mid west mountain engineering who make levers for our set ups with the added benefit of 50 percent less lever pull and in the size lever you want. 1 Share this post Link to post Share on other sites
Crazyced Posted November 9, 2015 Hi I also have the hacks magura kit on my 16 Yz 250. There is a company called mid west mountain engineering who make levers for our set ups with the added benefit of 50 percent less lever pull and in the size lever you want. Thanks, but the idea is to be able to order from a Canadian company, as our exchange rate is horrible right now. Share this post Link to post Share on other sites
YZCas27 Posted November 9, 2015 Thanks, but the idea is to be able to order from a Canadian company, as our exchange rate is horrible right now.Crazyced I don't think the levers will be that expensivive you should at least go on line and check them out. Share this post Link to post Share on other sites
johnnyboy Posted November 9, 2015 You must firstly find out what type of master cylinder you have, Has the lever got a small red adjuster or the alloy type pushing on a ball type ? Either one is the same as a KTM lever depending on the year as the later items are the ball type . Share this post Link to post Share on other sites
Crazyced Posted November 9, 2015 (edited) You must firstly find out what type of master cylinder you have, Has the lever got a small red adjuster or the alloy type pushing on a ball type ? Either one is the same as a KTM lever depending on the year as the later items are the ball type . I believe mine got a red adjuster. What years are we talking about? Edited November 9, 2015 by Crazyced Share this post Link to post Share on other sites
