Yamaha ttr 125 Carb Issues
Hey guys,
I recently took my Yamaha ttr 125 old carb off to replace it with a brand new carb. Being a rookie, I forgot to take pictures of how the different tubes hook up to the carb. I have done a little trial and error, but am not sure if I have found the correct hookup. When connecting it like I think I am supposed to, my overflow valve will pour constant gas out when the gas is turned on. My questions are...
1. Can you please help me correctly hook up the different tubes including the fuel line?
2. If the carb still overflows when correctly hooked up, how should I address this issue on a brand new carb?
Use Google to find pics of your carb and compare with yours to figure out the lines.
https://www.google.com/search?q=Yamaha+ttr+125+carb&tbm=isch&tbo=u&source=univ&sa=X&ved=0CE0QsARqFQoTCO_Qy-_xg8kCFQREJgodGpcF2Q&biw=2048&bih=1020
If when hooked up correctly, it overflows fuel from the bowl vent lines, your float level is most likely not set properly.
