removing xr400 odometer need a wheel spacer
I use the XR's Only kit on mine and suggest using that or something similar. That way you can remove the entire assembly and not just plug the cable hole at the hub. Much cleaner look also IMO. I just figured I did not want sand, mud and grit getting in there and ruining the assembly and possibly the bearings and hub as well.
This is a great part from Xrs only.Beware everything on there web site. Says in stock,when in fact no stock.If ordering from them call order part.Then ask go see if you have it,If he second later says we have it.Then they dont have it.
I made a similar part for one of my past xr400's out of t6 aluminum. easy to make one if you have a lathe,but 15.00 is pretty cheap to get one already made.Dont have that bike any more,so I cant give you the dimensions.
