01 Rm250 cylinder interchangeable
I'm not sure if this has been asked before or not but I'm still checkin around for a good cylinder for my 01 rm250. My question is, what all cylinders will interchange with a 01? Any info is greatly appreciated thanks.
I think all cylinders from 01 to 08 are the same but the powervalve setup changed from year to year so if you ended up with a different year cylinder you might have to drill and tap new holes for the powervalve retainer plate. Would be easiest to get the same year as your current one or get yours repaired if it's not too badly damaged.
