Crf250 won't kick start
Ok so I have recently rebuilt my bike and it's now time to break her in,I'm having trouble starting the bike using the kickstarter,it just won't start,but when pushed it will fire right up and run,then when it fired up the bike will not stay idle,it just turns off and I've made sure that revs are turned up from the carb,anyone know what this might be ??
This is your 6th+ thread on the same subject, and the 6th+ time you'll get these same answer:
- Have you checked your valve clearances?
- Have you checked your cam timing?
- Pilot jet and circuit clear?
- Carb rubber slide plate installed properly?
Edited by Eddie8v
