Te510 Clutch - Oberon vs Zipty/7602
Hi all, A decent amount of hours ago I had some clutch issues, i replaced the piston with a 7602 unit and the problems went away. Well, they seem to be back and the slave bore is damaged beyond with the 7602 piston can repair.
It seems the two common replacement options are the 'all in on' Oberon unit from the UK, or the 'separate combination' of a Zipty housing and a 7602 slave. There is little information out there about what product is better. It seems that noone has said a bad thing about the Zipty/7602 unit whereas i did read the Oberon unit had an issue for someone on this forum, but I wasn't able to find specific details as to what the problem was.
Being in Australia, the costs for both units works out the same.
So, which one should I go for?
I have seen a couple of people have problems getting the oberon unit to work. I haven't seen any with the zipty/7602 solution.
