Split Case now Weak Spark
What should I check first?? I split the case to replace the gear spindle and can't imagine what I did... I did replace the spark plug already.
Make sure the the ignition pulse generator is grounded to the case under the ignition cover.   I had this once not be grounded and it would not produce a spark.  Took it off and cleaned up where it mounts to the cover and it started working.
Next thing, like above, check grounds.  Try a different plug.  Check all wiring connections.  If you split the cases you would have had to disconnect all of the connectors under the seat to get the motor out of the frame.
Finally if all else fails, start upstream and trace back where you stop getting power.
You can barley see it.. It was very hard to turn the crank and watch for a spark on my own the spark was so small.
