04 rm85 gray oil
Whats up guys.. i recently got an rm 85 changed all the fluids in it and the oil comes out gray like it has water in it.. i changed it twice so far. Its running 155psi on the top end i dont know if thats good or not. The radiator fluid has not gone down any so i dont think its mixing with the oil theres also no metal shavings in the oil. Any ideas? Thanks guys!
I had to change my oil 3 times after drowning it in a creek before it was completely clear again if that helps any. I also started it and let it run for 15 minutes before changing it each time.
The aluminum plates in your clutch causes this. It's not bad. Aluminum breaks down overtime causing the gray coloring.
ooo okay.. should i be worried for my clutch? It doesnt slip or show signs of wear
