New motor....New issue(650)
Picked up a 2012 motor with 1300 miles on it, put into my 650, after I hit the starter the first time, the motor turned over for a split second then sounded like it locked up, after more troubleshooting I currently have the inspection plug out and initially had some movement manually attempting to rotate the engine counter clockwise but the engine would lock up again and I would hear a clunk from what sounds to be in the transmission like it was jamming up on something inside. I was able to shift thru all the gears with little issue. Idea's?
you need to take off right side clutch cover and twist on left and right and try to find all gears, if some of gears
are hard to find . you need open the engine and i think ur shifter is &%$#@!...t or ur gears
