Help with a 03 TTR 225
I'm working on a 03 225. It wouldn't run unless I shot some ether into the intake. I took the carb of to clean it and the screwdriver slot in the pilot jet is so screwed up that I can't get it out. So, I cleaned the rest of the carb and put it back on. It runs fine with the pilot screw out 3 turns. 2.5 turns if bogs off idle w/o the choke on. Idk if it's worth the risk of messing up the carb itself to get the pilot jet out or run it like it is. This bike is not going to be hopped up or modded. It's bone stock and it's fine for the person that rides it.
Thanks.
