85cc 2 stroke psi
Unfortunately I don't know what the average compression should be on an 85cc
but as Hedgehog 33 said that is likely very close to having a 'fresh' top end.
(taking in consideration the comp. gauge is accurate too)
A good rule of thumb for the recreational rider as to when to refresh a 2 strokes top end
(I'll take a 125 as an example as I'm more familiar with those numbers)
is to take a compression reading once a new piston & ring are installed and properly broken in.
Say your new top end gets 180psi, by the time the engine looses 10-15% of it's 'fresh' compression value,
in this case when it falls to about 155psi-160psi it's time for a refresh.
Take a few readings during the season to monitor the drop.
As an example I get about 20 hours on my recreational MX'ing YZ125 before loosing 10%.
A serious racer will want to refresh top ends much sooner, perhaps at only a 5% drop to always have a strong performing engine
and as preventative maintenance to avoid component failures from sustained high rpm use.
Edited by mlatour
