Maintenance help!?
So im just curious as to what are some things to look into changing after buying a used bike i already did oil and spark plug
Give it a thorough check over, look for worn parts and replace them.
Check for proper function of brakes, linkages, bearings etc and service if required.
Perform a top to bottom bolt check.
Set the suspension to standard and set sag.
Other than that, add pesonal touches such as grips and bars of choice, then go ride!
Edited by RussB69
