2016 YZ250X Wheel Swap
They should you'll need the bigger spacer as the axle is bigger than an 05 on the newer bikes.
If the axle is bigger, the bearings and inner spacer will also have to be changed.
I know for sure the rear is the exact same as earlier Models , as I have had my 19 inch on that has Equilibrium tire on it .
