95 xr100-crf100 front fender
Yes, but you need the bracket.  it shows it being a different part number.
Idk, I mixed and matched so many XR's, I'm sure I did. All the bottom triple clamps are the same, except the bearing part.  If you get a chance, you should buy 2001 or later bearings.  They come in races.
The fork bearings pre-2001 are just a of loose balls.  After 2001 they actuuly put them in races.
It does when you takes your forks off and they all bounce on the ground and you loose half of them. Then when put it back together, a second job, takes a frustrating twenty minutes.
