Whine in 3rd
Hi crew.
I have the ACT WR gears in my bike and have noticed a whine in 3rd. Very noticeable if rolling down a hill in 3rd without much throttle or when coasting through town. Sounds a bit like turbine. Goes away when the clutch is pulled in.
I currently have my engine spilt to install new main bearings, perfect time to try and see what is causing it. Have yet to find any signs of contact, something that might be touching etc.
Anyone had the same issue, maybe knows what could be the cause?
Thank you kindly for your time.
Regards
Sounds like gear whine from gears not perfectly matched from new or warn from long service.  How long have the ACT gears been in service?  Did it whine from the beginning?
They have done about 5,000ks and I noticed it from the start. There are little marks on the 3rd gears, the rest look clean.
Yes, talk to ACT.  Might be worth while to send them the 3rd gear set for inspection.
Ive sent them a mail, they requested some photos of the gears.
I live in AUS and the DRZ is my only transport, really hope I can sort it without sending the gears away. Can't be without wheels for so long.
I have an ACT transmission and mine whirrrs in third as well, no noise like this in any other gear. I have about 4000miles now and it did it from the start... it has never sounded like a "bad" noise just a whiiiring turbine sound as you described.
Thats is exactly what I have.
I have my case split at the moment and there are signs of wear on the 3rd gears, little line that runs across the face of each tooth.
So it might be worth trying to fix in your case as well, or I guess it will lead to premature failure.
im not worried...is ACT worried? can you post some pics of the line you speak of?
Im not super worries either. But I did put the ACT gears in after my original ones went boom so just a bit cautious.
Will post pics and feedback from ACT when I have it.
