2003 yz250f
other than your normal checks on any dirt bike... make sure the dipstick threads arent stripped (oil is stored in the frame) as well as the drain bolt on the frame. everything else would be normal checks.. fires up on first or second kick, ride it around.. listen for engine noise.. hows the clutch.. check wheel bearings, suspension, steering stem.. look for oil leaks on cases, countershaft sprocket seal.. pull the seat and look at air filter.. if he couldn't at least clean the filter before you came to look at it.. it will tell you a lot about his maintenance in general.. i always clean mine after a few rides or after one really dusty ride.. spin the tires and check spokes.. there are a lot of simple checks that will give you a good idea of the level of maintenance the bike received during his ownership
