Yamaha YZ lower fork tube
Ok, so I've got a set of 06 250f forks on my 05 yz250. The fork lug on the left/brake caliper side has play in it. I've looked/read about trying to take it off but decided against that. Trying to find a used set of lower legs but I'm not sure if they're any difference in length between the 250f and 450f legs. Does anyone have a clue on the size difference?
I've checked in the .pdf version of the KYB parts catalog I have here and unfortunately
there doesn't seem to be compatibility for your application with any other models/years.
Part 79.4 'innertube assy complete, left side' (lower tube assy.) of the closed chamber fork diagram page #17,
Part application details on page #103, KYB part number: 110794803801
There is a specific part number for the 2006, also a specific one for the 2007,
from 2008-on the lower tube assy. seems to change only every 2nd year of production on the 250F.
You can download the KYB catalog on the Technical Touch USA website :
http://www.technicaltouchusa.com/
As to what is different between say a 250F and 450F lower tube ?
lenth, hydraulic bottoming lock ? I would be curious to know...
EDIT: corrected the part number
Edited by mlatour
So I looked at the part numbers and seen this :complete left inner tube with lug YZ250 -2008-2014 110794504801, , which also is the same as the YZ250f 2008-2009 110794504801. So that gives me hope that they may be the same length, but not so much for the 450f with 2006-2007 110794803401 2008-2009 110794805001.
I have several sets of the 06'-07' lowers complete if you need a set. Call me 740-988-6673 and I'll help you out
So are these 250f, 450f, or 250/125 lower legs? Also can I text at this number so maybe you could send me some pics of the legs?
I have pretty much all of them.  The 07' 250f is the only one that's not the same as the other 06/07's.  It was the first bike to get the newer lugs and caliper.
Do you need a set of them or just one specific side?
And yes that number you can text.
I just need the caliper side, but would take a set if the price :)  was right. I have the older caliper hanger, so the 07 250f wouldn't work for me.
