2013 kfx 250. Need the map plugins.
Just picked this bike up today. I need the map plugins or pics of them to see what wires they are jumping to switch the map.
Thanks in advance
1114150949a.jpgI take it they didn't give you the manual either? It shows them in wiring diagram. If you are savvy with soldering and simple wiring you can use a DPDT 3 position toggle switch and use the switch to select maps. That's what I did. You have to use a white coupler though since it has 4 wires coming out already. A coupler is only about $12 i think. If no coupler is present then it defaults to the standard map, as said in manual. I don't know why the green coupler has a jumper in it then...
