83 yz 490 clutch problem
I have this 83 yz 490 and everything works fine. The clutch seems a little halder to pull then normal. I unhooked the cable. Cables good.I pulled the clutch arm out. thinking maybe i would try and lengthen it. When I tried to put in back in I could not get to go all the way in. I  pulled it apart to check it out. When i pull the pressure plate off i thinking there should be a ball that comes out next. No ballI  Could someone have put the ball in before the push rod and when I pulled out the arm the ball has dropped in where the shaft of the clutch arm sets and thats whats keeping the clutch arm from going back in?
Edited by TJDESIGNS
