2001 YZ250 -HELP .. What's This?
Hi, removed the engine from the frame, in preperation to do a bottom and top end rebuild.
I almost have it back together and this is " left over."
It's not from inside the bottom end....
Is it from the Power valve area?
is it a seal from a electrical connection?
Think I went through every parts diagram.
Can't find it.
Come on...anybody else?
Don't want my freshly rebuilt engine blowing up on me. .
I couldn't stand another 3 months off the bike.
Edited by YZ Yankee
It looks like the seal that goes in first for the stator plug I believe. Maybe the CDI or coil but I think it's the stator.(under the tank not down low)
If that's not it put a ruler or quarter in the picture with it to give us some scale.
Edited by mikeylikesit
  • Like 2
That is certainly not an internal engine part. I agree with the others.... looks like a seal in one of the connectors. MikeLikesIt is right... try taking a pic of it next to a ruler.
  • Like 2
Frank,
Check the connector from the stator, at the harness by CDI box. Without a tape measure, coin, finger next to it I can't tell the size. That has got to be the seal in that electrical connection.
Thanks guys... I had a feeling I should have put some reference to the size...
It's a about .75"x.5" (inches ).
It's got that little groove all the way around.
PS
There is a remote possibility it belongs to the YZ426 that's also apart.:huh:
Edited by YZ Yankee
It's a rubber grommet (insulator-boot) that came out of 1 of the electrical plugs
Palmer840ne posted about electrical seal then Mikeytlikesit said something about it as well
I've attached a pic of Stator & CDI unit to compare it to:
I had 1 come out of a plug-in (almost exact) &
It had me :banghead:  dumbfounded as well.
Took me awhile but I finally figure out where it came from :applause:
Hope this was of some help.
TY-250-Dav
TY-250-Dav
Ahhh. I'm going to check that. I couldn't find anything external and the plugs snap into eachother, but for this to slide down into the plug.... I would of never found that.
Thanks for posting.
