Air filter
K&N are an absolute NO in off road in dusty conditions.  This has been discussed here many times.
Edited by cjjeepercreeper
  • Like 2
Nothing wrong with the Uni other than with some of them, you really can't use the OE air box that are many times.quite good for deeper water.  Just use good cleaning and oiling products for the Uni.
Will it be ok to cut the piece of foam that bridges across the back side of the Uni filter...
seems it hinders the cage removal and it seating on the XRs filter mount..
It'll stretch! If you do cut you risk it coming off one side a little and not sealing against thr airbox. Just be real careful installing if you do. Myself, I'd rather just deal with the little foam strap.
