2003 Xr100 Rebuild. Need general advice. +BBR 120 Kit install
Hey guys. lost compression so I purchased a BBR120 kit and Kitaco high flow oil pump.  Just curious if there is anything else I should look into replacing while im in there.  Such as the timing chain or timing chain gears.   It looks pretty decent with the valve cover off, and the chain doesnt look like it has any movement side to side...
thanks!
also any tips on the BBR 120 kit install would be great
I would just check the valves for leakage, using wd40 or something similar.
