kx250 jetting
can anyone point me in the direction of a kx250 jetting database (searched and cant find)
or give me some info on jetting for my altitude and heat and humidity
i am in australia and ride trails/ enduro
so far my jetting is as below:
all riding at sea level
fuel mixture 40:1
pilot jet 42: (plug showed dark brown colour
air screw: winter  (15 - 25 degrees celsius  30% humidity )1.5 turns  / summer 1.75 turns 35-40 degrees celsius / 95 fahrenheit ?
80-90% humidity
needle: 3rd clip (standard as far as i know)
main jet : 158 (plug chop showed light brown/ tan colour)
does not seem to slutter on to needle
no spooge and just a little whisper of smoke when revved
mods are fmf gnarly pipe and v force 3 reeds
am i heading in the right direction ?
thanks in advance guys
What year is your KX?  In my 2003 these settings would be really lean at that elevation, but it seems to be working well for you.
I would probably try dropping the needle one position.  I am running the same main and a smaller pilot in mine but I ride at about 5000 feet ASL.  A 155 main would be just right for me but mine snapped off last time I used it.
I'd say you're pretty close.
I know you can buy the jetting chart from JD Jets. Off the top of my head I want to say it is $20 and he sends you all his info in an excel sheet
Dyldog it is a 2000 model
Do you think the main is to lean ?
Is it costing me power ?
Edited by kxrob
If the main was lean you would likely see that in the plug color but it sounds like you have a good color on yours.
will find pic of plug
Edited by kxrob
Thanks shrubitup :
everything looks similar to what i got except if i ran a 50 pilot i'd be fouling plugs all the time
i think the pro circuit settings would be okay for 32:1 (leaner on fuel) and for motocross where your not on the pilot circuit a lot
i think i pretty much got it dialed in now , just interrested what ours in similar conditions were running
What's the history of the bike?  Did you just buy it or was it stock and you put the pipe on?  You generally go leaner with the Gnarly pipe.
Had bike for over a year and jetted to specs in 1st post
Just seeing what other people run in similar conditions
Bumping post ,
Im thinking about making the switch to full synthetic pre mix and going to 50:1
Most of my riding is from idle to 1/2 throttle in third gear
I was going to rejet by going to a 42 pilot (adjusting air screw to suit ) and dropping needle down by raising clip to 2nd position ( clip in 3rd position at the moment)
What is a good replacement needle for the stock one (n3we ? Is in it now)
Sorry for a long post but I'm on a quest to have it run as clean as possible at idle and up to over 1/2 throttle
Goal is to have minimum smoke and a clean running pipe
This is my pipe after today's ride
It was a hot day (35degrees Celsius/95 Fahrenheit)
And at sea level
admirable looking pipe there. I wouldn't try to lean it out based on that. Many have the drool running down whole pipe and dripping on swingarm.
Pro Circuit says N3WF. I used their recommended settings for my 99 other the pilot jet which is a 48 vice the 45 they say. May switch back to 45 in the summer but it Works great!
pipe is pretty wet with oil inside .
when it gets revved  past 1/8 throttle it is a bit oily and takes a bit to clear out
im going to repack silencer soon and clean out the expansion chamber as well
