Wr250f big bore
I've been trying to get more bottom end power for my 2002 wr250f it doesn't have much low end power I'm just wondering if a 290 big bore will add more power down low but still keep the top end power it has.
For the most part yes.  I didn't notice any loss in top end power, but I started with a ported head and stock cam.  Unless you like to hold the throttle wide open and bounce off the rev limiter on straight a ways, I think it's a good mod.  You'll notice a lot more low end power.  Make sure your clutch is in good shape.
Before I'd spend $$ on a big bore, have you regeared and rejetted? There's much to be gained by getting those right and far less expensive.
Also, changing the cam timing tl yzf specs yielded great results. The bike ran like a yz with heavy flywheel and wide ratio gears.
