Compression maintenance? 2 stroke
Whats up guys i just got a 04 RM85L and im just wondering what i can do to get the absolute best performance out of it.. all i did so far was change all the fluids and it always starts first kick.
To get the best performance make sure that the top end is fresh, the air filter is cleaned regularly, the jetting is correct, the gearing is right, the clutch isn't worn and the suspension is set up for your weight and ability. This includes fresh oil, proper springs, greased suspension linkage. Fresh tires helps too. Once you get all of that worked out then you can consider upgrades. High performance pipes on clapped out bikes won't make them faster.
