Speedometer correction for motard conversion
Hi guys, 3 months owner here of 250L.
I've used the "search" tab and didn't see related topics.
I've ordered from a local store here (Manila) a set of hubs and rims from a 250M, and plan to swap occassionaly from dirt to motard.
Since the L is rolling on 18 and 21 rims, is there a way to re-calibrate the speedo to get an accurate reading when I swap to 17's? Or do I just have to install Vapor Tech like products?
Thanks in advance.
If you use the stock gearing with the L wheels the stock 250M gears will be fine. it uses a 39 tooth rear sprocket to achieve the same overall gear.
There are lots of links about the DRD speedo corrector most members are using since they run different gearing.
http://www.thumpertalk.com/topic/1058051-speedo-drd-setup-question/page-4?hl=%2Bdrd#entry12437146
http://www.thumpertalk.com/topic/1051733-speedometer-calibrations/?hl=%2Bdrd#entry12203092
http://www.thumpertalk.com/topic/1115367-speedo-calibrator/?hl=%2Bdrd#entry12079930
  • Like 2
