need to find steel friction discs: 1.5mm.
hi men
i want to swap my aluminum friction discs for steels in my CR250 2007
I have searched throughout oem references but the most suitable seem to be the CRF's but they are are 1.6mm.I need them to be 1.5m  not to vary the height stack and start having more problems
do you know some other honda model that has the same disk but steel in 1.5mm??
i prefer honda frictions  because they are the best ones for me
thanks you all
the steels of my CR250 '07 are 1.6mm
i need steels 1.5mm thick and with the same pattern to fit the inner hub
if i get all steels in 1.6mm , the overall height stack (steels + frictions) will increase 0.5 mm
that means the clucth will drag in too much excess or do nothing
Edited by frenando
I put a cheap tusk kit in a couple weeks ago. I think the steels were 1.58. Clutch doesn't drag. More effort at the lever than before but my aluminum plates were worn WAY down.
