2015 kx450 top end noise
2015 kx450 maybe 15 hrs.started makin loud noise..replaced cams cuz shot and new timing chain..but still gettin noise??any help thx
Were the can lobes worn? How was the surface of the head where the can rides? Did it ever run out of oil?
Yes the cam lobes were worn bad I used a caliber. .run out of oil not that I no of its my son's bike.head were cam sits looks fine
If the wear on the can lobes is visible, then there is or was a lubrication problem. When you say the rod hits the sides, what do you mean? Do you have the piston off? Take pictures.
