02 cr250 suspension rebuiild pivot works
Anybody have good luck with pivot works rebuild for forks and shock kit? Look of a decent price for them and only kit I find complete assemble instead of ordering piece by piece. Thinking of going with race tech springs and gold valve.
I would go with oem on the shock seal head. The aftermarket pieces seem to be a bit loose (in comparison to stock) on the shock shaft.
Skf seals & wipers are excellent in the forks. Oem are my next choice.
Order oem (stock) fork bushings. Again, the best fitment.
Gold valve stuff is overrated & you have to do everything yourself. Just pick a reputable tuner & send your suspension in. Mx tech out of Illinois is very good.
Okay that's what my friend said wait wouldn't do pivot work and said same skf seals best and wipers. And to go with oem. But looks for a complete rebuild and receive and springs and friend is a cert tech for race tech and seems to be cheaper than most places I've been quoted in AZ. But still on the search. Thanks for your input guys
If you can get the racetech stuff at a discount & have a friend to service it for you, give it a try.
