MOTOLED Edge taillight question
I just installed the MOTOLED Edge taillight on my DRZ-S and I think I'm wondering if any of you have had the same issue I encountered. When I was connecting the three wires in the kit to my stock harness the instructions said that I should have had black w/white stripe, white w/black stripe, and grey. The third wire in my harness is brown, not grey, but I hooked it up per the instructions with that caveat. Anyway, when I attach the ground and the taillight wires, the light comes on in the "normal" fashion, but the second I connect the brake light wire, the taillight stays on in full "my brakes are on" mode. Not sure if there was built up residual pressure in the system causing either the front or rear switch to activate, but that's what it was doing.
Thoughts?
Chuck
