Jet less carbs ?
No such thing as a 'jet-less' carb. Even the Lectron and Smart Carb use jetting, just a different style of jet. (tapered rod that proivides fuel flow control at idle (pilot) mid range(tapered needle) and WOT (Notch on the end of the 'metering rod'.)
A 'jet-less' carb would be fuel injection.
You are not going to get FI on your YZ.
Yes that's what I meant the ones like lectron do you think there better then a keihin carb jd jetted
If you believe the testimonials they are...I ordered one last week and should have it by Thanksgiving. I feel like I had my Keihin pretty well dialed in...we will see.
https://m.youtube.com/watch?v=D8qWyRH4-UM
Edited by poldies4
I think my YZ runs just as well with the Keihin as my previous Husky did with a Lectron. The Lectron was significantly better than the Mikuni the Husky came with. I kept the Lectron when I sold the Husky, but it was way too long to fit the YZ. The YZ runs so well, I have no reason to invest in a short Lectron, which still apparently is a very tight fit.
Speaking from ' a lot ' of experience,
with carbs, efi, etc, etc, get some jets
and needles, and maybe a cheap
( $40 to 60 ? ) ultrasonic cleaner.
You wont believe how fast a carb
can get gummed up with fuel, oil,
water condensation, sludge, that plugs
( or more correctly ) changes the
sizes of all the mini orrifices in a
carb. Usually after doing an ultrasonic
cleaning on a carb, and jetting in
the ballpark, with a fairly decent
condition motor, they seem to always
start with 1 to 3 kicks.
I just ordered the keihin 38mm air Stryker pwk jd jetted so I don't have to deal with any problems with fitting the lectron in my yz I just want that crisper throttle and a little better response
