cyclerc Posted November 21, 2015 (edited) Any valving for kx450 2016 to try? I using stock with 2 clicks comp and feel harsh in small bumps at low speed! I need more plush rides for Florida bumpy trails , 185 lbs b rider Sorry for the title! How I can edit the title? Edited November 21, 2015 by cyclerc Share this post Link to post Share on other sites
mog Posted November 21, 2015 Look at the crf 250 valving and compare to yours ,you should see the differences Share this post Link to post Share on other sites
cyclerc Posted November 21, 2015 (edited) The crf250 comes with showa sff 50mm? Edited November 21, 2015 by cyclerc Share this post Link to post Share on other sites
mog Posted November 21, 2015 49 ssf air ,is yours 50mm Share this post Link to post Share on other sites
cyclerc Posted November 21, 2015 49 ssf air ,is yours 50mm 50mm Share this post Link to post Share on other sites
Piney Woods Posted November 21, 2015 (edited) The title is irrelevant at this point. What you need to do is be more specific and clear in your post. What does "2 clicks comp" mean? More or less than stock settings? The more accurate info you can give the more help folks can give you. Good luck. Edited November 21, 2015 by YHGEORGE Share this post Link to post Share on other sites
cyclerc Posted November 21, 2015 The title is irrelevant at this point. What you need to do is be more specific and clear in your post. What does "2 clicks comp" mean? More or less than stock settings? The more accurate info you can give the more help folks can give you. Good luck. 2 CLICKS IN FROM ALL SOFT BASIC ALL SOFT IN COMP REB 12OUT Share this post Link to post Share on other sites
cyclerc Posted November 24, 2015 No body change the valving of kx450 2016 for offroad? Share this post Link to post Share on other sites
Vietze Posted November 24, 2015 The title is irrelevant at this point. What you need to do is be more specific and clear in your post. What does "2 clicks comp" mean? More or less than stock settings? The more accurate info you can give the more help folks can give you. Good luck. Thats irrelevant too. He is using a MX bike for harescrambles... Its quite obvious that its too stiff. You just need it to be softer overall. The 2015 CRF 250 Base valve might be a very good base line for further testing. However, your mid needs to be softer too and more float for offroad use. use 10 PSI less in main and balance chamber as a start point. Share this post Link to post Share on other sites
mx317 My Ride Posted November 24, 2015 50mm 49mm fork tubes and 50mm shock body to be clear Share this post Link to post Share on other sites
